laural_
May 15, 2014
Building a String with Columns
I am looking for help switching between column names (e.g. :Height) and strings ("Height").
In this script, I am building a string to use in the table join command.  I am using the bylizt earlier in a script for a table summary so I like the bylizt as columns.   The dialog box returns a list of columns; in this example, there are two columns, but there could be any number of columns.
bylizt = {:Rec Type, :Step};
I want to take this result and build a string to insert into the join command.
MatchColString = " :Rec Type = :Rec Type, :Step = :Step";
Is there an easy way to build this string?
Ultimately, this string goes here:
Eval(Parse(Eval Insert("
wrefdt = cdt << Join(
With( Data Table( subsumdt ) ),
Merge Same Name Columns,
By Matching Columns(^MatchColString^ ),
Drop multiples( 0, 0 ),
Include Nonmatches( 1, 1 ),
Preserve main table order( 1 ),
Output Table( newname )
Laura
pmroz
Jun 23, 2011
Solution
Re: Building a String with Columns
It would be easier to get column names as strings, but this will work:
for (i = 1, i <= nitems(bylizt), i++,
	one_col = ":" || char(bylizt[i]);
	if (i == 1,
		matchcolstring = one_col || " = " || one_col;
		matchcolstring = matchcolstring || ", " || one_col || " = " || one_col;
show(matchcolstring);
pmroz
Jun 23, 2011
Solution
	if (i == 1,
laural_
May 15, 2014
I agree that it would be easier to get the column names as strings, but I am using a column dialog box, so you get what you get.
Laura
