dketels
Community Member
Bubble Plot - Set a Dynamic color scale for each column subset
I'm writing my very first jmp script and need some help.
So far I started off creating bubble-plots to better visualise my data repeatability distribution in X and Y coordinates for each part I measured.
Bubble Plot(
	X( :X ),
	Y( :Y ),
	Coloring( :Name( "3Sigma_BH" ) ),
	Show Roles( 1 ),
	Color Levels( [0.54 8.902325 17.26465 25.626975 33.9893] ),
	Title Position( 0, 0 ),
	Local Data Filter(
		Add Filter(
			columns( :Name( "3Sigma_BH" ) ),
			Where( :Name( "3Sigma_BH" ) >= 0.54 & :Name( "3Sigma_BH" ) <= 33.9893 )
	By( :PartID ),
		Dispatch(
			"1",
			ScaleBox,
			{Format( "Best", 10 ), Min( -9000 ), Max( 9000 ), Inc( 2000 ),
			Minor Ticks( 1 )}
		Dispatch(
			"2",
			ScaleBox,
			Minor Ticks( 1 )}
My problem is with the color scale, I'd like it to dynamically range from each part's min to max.
The variable I try to capture is 3Sigma_BH (which I use for coloring), my column I use for subsetting is PartID. Because of this fixed color-scale I loose context, cfr pic belowjmp temp.PNG
I thought of either:
  1. Subset my dt by partID before plotting and create a simple function to loop through all partID's at each iteration adding a new bubble plot
  2. Create a function to extract the minimum for my current
	dtData = currentdatatable()
for each :PartID in dtData ( rows = dtData << get min( :3Sigma_BH) minBH = Min( :height[rows] ); maxBH = Max( :height[rows] );
Any suggestion on how to do this and/or better options than the two above?
Thanks!
Diego
Re: Bubble Plot - Set a Dynamic color scale for each column subset
Hi Diego - from the red-triangle menu, try turning off "Lock Scales".  This option applies to both the axis scales and the color scales, and can also be set as a preference if you always want this behavior.  With the setting turned off, the Color Levels() and SendToReport() parts of your script should go away when you re-save the script.  Here's an example from the sample data:
Open("$SAMPLE_DATA/San Francisco Crime.jmp");
Bubble Plot(
	X( :Longitude ),
	Y( :Latitude ),
	Coloring( :Time ),
	Lock Scales( 0 ),
	Local Data Filter(
		Add Filter(
			columns( :Category ),
			Where( :Category == "ARSON" ),
			Display( :Category, Size( 139, 221 ), List Display )
