BookmarkSubscribeRSS Feed
matt_p
May 25, 2012
Break up a Journal into individual graphs?
I am looking to break a journal up into the individual graphs that make up the journal.
The idea is that I am prompting a user to save graphs, and I would like to be able to save individual graphs from within a journal, rather than the journal as a whole.
Any help is greatly appreciated.
-Matt
XanGregg
Jun 23, 2011
Solution
Re: Break up a Journal into individual graphs?
Each graph is wrapped in something called a PictureBox, which is how the HTML export knows when to make an image file. You can cycle through the PictureBoxes with display box subscripting, or use XPath:
jrn = Current Journal();
graphs = jrn << xpath( "//PictureBox" );
n = N Items( graphs );
For( i = 1, i <= n, i++,
  graphs << Save Picture( "$DOCUMENTS/pic" || Char( i ) || ".png", "png" )
6 REPLIES 6
XanGregg
Jun 23, 2011
Solution
matt_p
May 25, 2012
That worked great Xan, thank you very much.
The next hurdle I need to get over is grabbing the title for each graph in the journal. Each graph is wrapped in an outline box, with its title in that. Is there anyway I could call the parent to the PictureBox and grab the text from it?
Thanks again,
Matt
XanGregg
Jun 23, 2011
There is a <<parent message, but you may have to apply it several times to get to the OutlineBox if there are intervening boxes like ListBox or BorderBox. You can use <<classname to see what type of box you're at.
Doing the same with xpath gets a little trickier, but this works in the loop:
  print((jrn << xpath(EvalInsert("descendant::PictureBox[^i^]/ancestor::OutlineBox[1]")))[1] << get title)
matt_p
May 25, 2012
Great work again Xan, worked like a charm.
The timely response was extremely helpful as well.
matt_p
May 25, 2012
I have one more question Xan. I am not too familiar with the ancestor/descendant part of the trees.
I now have the user selecting a graph name from the list that was created using
From the title they choose, I would like to find the corresponding picture box and save that to a file, instead of all of the picture boxes.
I was thinking of replacing ancestor::OutlineBox[1] with the title of the graph, and the descendant would be PictureBox[1], correct? From that would I be able to save the picture?
Once again, any help is greatly appreciated.
-Matt
XanGregg
Jun 23, 2011
One approach would be to collect two lists: one of picture boxes and one of titles. Then, if they select the nth title, then output the nth picture box. To get the nth picture box on demand, I think xpath //PictureBox would do it.Or use the regular Display Box subscripting: jrn[PictureBox(n)].
