morenopelaez_p
Blob variable crashes mySQL query with query builder.
I have a database that contains small images in a blob variable. I have tried to query it with query builder but the whole query does not work (columns come up empty and the blob is not imported).
Can I import blobs with query builder or is this just not supported?
stan_koprowski
Re: Blob variable crashes mySQL query with query builder.
JMP does not support directly the import of BLOB objects with Query Builder at this time.  JMP ignores the BLOB object because it does not know how it should be interpreted.
Alternatively, you could do something similar as mentioned in this discussion Byte Array Image from Database to JMP
Thanks,
Stan
stan_koprowski
Thanks,
Stan
morenopelaez_p
Thanks Stanley, very clear. I will investigate what we can do via the solution you referred to.
That said, it would be a great new feature to be able to download pictures from a DB as we can now do with "internet open".
