BookmarkSubscribeRSS Feed
mikes1098
Mar 18, 2013
Bivariate Power Coefficient Curve Fit in JMP
I am trying to do a very simple Power Coefficient Fit in JMP.  In excel it is very simple – therefore I know JMP has to be able to do it…but for the life of me I cannot figure it out.... any ideas would be greatly appreciated
Simple Data Set Example:
Attatched
Excel fit that I am trying replicate:
ms
Jun 23, 2011
Solution
Re: Bivariate Power Coefficient Curve Fit in JMP
You can use the Fit Model platform or Fit Special in the Fit Y by X platform. Fit Special is found under the red triangle in the Fit Y by X report. Choose log transform for both Y and X variables.
A scripting example:
Bivariate(
  Y( :y axis ),
  X( :X axis ),
  Fit Special( xTran( "Log" ), yTran( "Log" ), {Line Color( {208, 64, 86} )} )
Results in the equation Log(y axis) = -2,178489 - 0,3877925*Log(X axis),
which is equivalent to  y axis=0.1132 x axis^-0.388
ms
Jun 23, 2011
Solution
Bivariate(
  Y( :y axis ),
  X( :X axis ),
mikes1098
Mar 18, 2013
Thanks MS, thank worked perfectly... you have no idea how long I was looking for that....
