BookmarkSubscribeRSS Feed
mahroo
Community Trekker
Binary response_fit model
If the response variable is binary, can I still use fit model?
David_Burnham
Re: Binary response_fit model
Yes.  Although the personality will change to logistic regression instead of least squares regression
-Dave
David_Burnham
-Dave
mahroo
Community Trekker
Thanks for your answer.
My problem is actually that I have a split plot analysis, and when I put my whole-plot variable as a random effect in the "model effect" part, the logistic regression is inactive in the drop down menu?
who could I have a logistic regressing with split-plot analysis?
David_Burnham
As far as I'm aware JMP wont allow you to put a random effect into a logistic regression
-Dave
mahroo
Community Trekker
Does this mean for such analysis I need to use other packages like R?
