marcstein
Basic Confidence Interval Question using IVD Performance add-in
Sorry for asking what is likely an overly simple question, but...
I want to express Sensitivity and Specificity values at a 95% CI. When I run IVD Performance I see the following values:
Estimated, Lower 95% CI, and Upper 95% CI
In my particular model the Estimated.Sensitivity is 0.982, Lower.Sensitivity is 0.959, and Upper.Sensitivity is 0.992
If I want to represent the 95% CI value, is it the Estimated value?
Thanks in advance!
Marc
Re: Basic Confidence Interval Question using IVD Performance add-in
The estimate of the sensitivity based on your sample of data is available as a point estimate and a confidence interval estimate. The point estimate is 98.2% The 95% confidence interval estimate is 95.9%-99.2%.
marcstein
Thanks!
