TWE
TWE
Bar chart variable by list
I try to script a bar chart like this one.
Graph Builder(
	Size( 534, 418 ),
	Show Control Panel( 0 ),
	Variables(
		Y( :Name( "A" ) ),
		Y( :Name( "B" ), Position( 1 ) ),
		Y( :Name( "C" ), Position( 1 ) ),
	Elements(
		Bar(
			Y( 1 ),
			Y( 2 ),
			Y( 3 ),
			Legend( 3 ),
			Bar Style( "Stacked" )
The challange is, that I have the Y variables in a list which will be changed from time to time (e.g. {A, B, D, Test, Bla}).
I would like to have the bar chart automatically adjusted dependening on the list "l" e.g:
l = {"A", "B", "D", "Test", "Bla"};
...the script should then be looks like this:
Variables(
		Y( :Name( "A" ) ),
		Y( :Name( "D" ), Position( 1 ) ),
                Y( :Name( "Test" ), Position( 1 ) ),
                Y( :Name( "Bla" ), Position( 1 ) ),
Elements(
		Bar(
			Y( 1 ),
			Y( 2 ),
			Y( 3 ),
                        Y( 4 ),
                        Y( 5 ),
			Legend( 3 ),
After an database query the list l will be changed and I need an automatical update of the bar chart.
I already tried to transform the list into a column and  loop over the number of list entries but it generates multiple instead of one bar chart
for (i=1, i <= Nitems(l), i++,
show (l[i]);
dt << Graph Builder(
	Size( 534, 418 ),
	Variables(
		Y( Eval (l[i] ))
	Elements(
		Bar(
			Y( i ),
			Legend( 3 ),
Regards,
pmroz
Re: Bar chart variable by list
If you stack the desired columns then it doesn't matter how many you have.  This code should get you started:
dt1 = New Table( "Untitled 27", Add Rows( 3 ),
	New Column( "A", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [6, 5, 4] ) ),
	New Column( "B", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [7, 8, 9] ) ),
	New Column( "C", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [3, 2, 1] ) )
col_list = dt1 << get column names(string);
dt2 = dt1 << Stack(
	columns(col_list),
	Source Label Column( "Variable" ),
	Stacked Data Column( "Value" )
dt2 << Graph Builder(
	Size( 526, 415 ),
	Variables( Y( :Value ), Overlay( :Variable ) ),
	Elements( Bar( Y, Legend( 8 ), Bar Style( "Stacked" ) ) ),
	SendToReport( Dispatch( {}, "X title", TextEditBox, {Set Wrap( 2 )} ) )
pmroz
dt2 = dt1 << Stack(
	columns(col_list),
	Size( 526, 415 ),
TWE
TWE
Thank you, this works fine!
