illinitom
Bar Chart fill color
I run a regular script that does a line chart overlayed onto bar chart via graphbuilder.  Unfortunately, the Y data is the same for both, and both bar and line show up as same color.  The only way I see to change the color is with mouse/right click/fill color once the chart is complete.  This doesn't help my script.
Is there a way in jsl to dictate the color?
Re: Bar Chart fill color
Whne you finish making the change manully, then click the red triangle and select the command to save the script. The change of color should be part of this script.
