BookmarkSubscribeRSS Feed
DNAFoundry
Mar 17, 2017
Back Calculate Power From DOE
I have a DOE experiment and I am happy with the data produced and the model fit. Is there any way to generat power analysis numbers from the noise of this data to use for future experiments?
Dan_Obermiller
Apr 3, 2013
Re: Back Calculate Power From DOE
Not sure exactly what you are looking for. For the anticipated error most people use the Root Mean Square Error in future calculations and, of course, you already have the parameter estimates. You might also want to look at your model fit results and then from the red triangle choose Estimates > Parameter Power. Hopefully something here is what you are looking for.
Dan Obermiller
