BookmarkSubscribeRSS Feed
Axis Label Formatting In Variability Chart
ylee
Nov 16, 2016
In Variability Chart, depending on situations, it seems that JMP has an automatic way of deciding whether a label in the x-axis should be horizontal or vertical.
I would at times face with labels that are not displayed properly (example in picture below) where a number is displayed horizontally in two lines instead of one.
To get around this, I could make all labels with this data type to be vertical in all the charts:
Rotated Tick Labels( 1 )
But is there a way in JSL for user to query / find out if the label is displayed in two lines thus giving my script the information to intelligently Rotate the labels only when it is needed?
Thank you.
