Autoscaling box plots
Hi Guys,
Is there any way to autoscale multiple box plots so that the data is seen clearly (covering > 80%) of the window?
Thanks.
Re: Autoscaling box plots
Anybody?
Thanks.
rchertzy
Can you be more detailed in what you want? I make multiple box plots to check equality of means and size is fine, but that is done with oneway ANOVA so probably not what you are doing. Details?
