satish
Automation Error the requested operations requires elevation
I am trying to automate JMP from MS Access and struck with this error message: "Automation Error the requested operations requires elevation"
I am using MS Access 2010 (32bit), JMP 11 (64 bit) and Windows 7 (64bit). I added JMP as reference. Error is triggered at line 03
    Dim MyJMP As JMP.Application
    Dim JMPDoc As JMP.Document
    Set MyJMP = CreateObject("JMP.Application")
    MyJMP.Visible = True
    Set JMPDoc = MyJMP.OpenDocument("C:\Program Files\SAS\JMP\11\Samples\Data\Big Class.jmp")
Any pointers?
Thanks for your help!
Satish
