andreasp
Automating a DoE and fitting the Model
Hi
I'm working on a bit of software attempting to automate JMP 9 in C#, what I'm attempting to do is create a DoE, fill the data table with my results and then fit the model. I can get as far as generating the DoE and filling the datatable but I'm getting stuck at the final stage of fitting the model. My code looks a little like this (part of a larger class with Response, Factor and Term properties) :
JMP.Application jmp = new JMP.Application();
jmp.Visible = true;
JMP.DOECustom doe = jmp.CreateDOECustom();
foreach (JMPResponse response in this.Responses)
    doe.AddResponse(response.ResponseType, response.Name, response.Minimum, response.Maximum, 1);
foreach (JMPContinuousFactor factor in this.Factors)
    doe.AddContinuousFactorWithName(factor.Name, factor.Minimum, factor.Maximum);
foreach (JMPTerm term in this.Terms)
    doe.AddTerms(term.AsIntArray());
doe.MakeDesign();
JMP.DataTable dt = doe.MakeTable();
// Do bit's and pieces to fill the table
What I'd like to do next is Fit the model and then (hopefully) extract the various coefficients, t statistics and so on from each of the terms. I can't really find anything obvious in the documentation or the code samples that lets me do this.
Any help appreciated.
mpb
Super User mpb
Re: Automating a DoE and fitting the Model
The following pure JSL example may help. This kind of thing is discussed in the Scripting PDF doc under the heading Platform Scripting Notes.
Open( "$SAMPLE_DATA/fitness.jmp" );
fit_model_object = Fit Model(
    Y( :Oxy ),
    Effects( :Age, :Weight, :Runtime, :RunPulse, :RstPulse ),
    Personality( Standard Least Squares ),
    Emphasis( Effect Leverage ),
    Run(
        :Oxy << {Lack of Fit( 0 ), Plot Actual by Predicted( 1 ), Plot Regression( 0 ),
        Plot Residual by Predicted( 1 ), Plot Effect Leverage( 1 )}
vc = fit_model_object << Get Variance Components();
effnames = fit_model_object << Get Effect Names();
effpvals = fit_model_object << Get Effect PValues();
ests = fit_model_object << Get Estimates();
parmnames = fit_model_object << Get Parameter Names();
randeffnames = fit_model_object << Get Random Effect Names();
stderr = fit_model_object << Get Std Errors();
fit_model_object << Get X Matrix();
fit_model_object << Get XPX Inverse();
Show( effnames, effpvals, ests, parmnames, stderr );
andreasp
Thanks for that mpb, suspected that I might have to get down and dirty with JSL. I'll add for the benefit of any future users wandering around these parts that the Automating JMP using C# document has some good information on how to access JSL variables and the like.
