Attaching through JSL to a DOE object already created
In a previous thread, I got (thanks xan) a good tip to access a report parameter using this code:
obj=DOE();
display=obj<min runs = display["Design Generation"][number col box(1)][1];
This works great, but in my case I'm not creating the DOE object from JSL, but from another application that does it through COM.
How can I "attach" obj to the DOE that has already been created, rather than instantiating a new DOE? Is that possible with JSL? Trough COM I have the option of doing this kind of call once the JSL parameters are ready to be read:
jmp.RunCommand("JSL statement");
So it is just the right JSL statement to attach to the already existing DOE what I'm missing.
Sorry, this may be a naive question for JSL developers, but I'm not an expert on this.
Thanks
Jesús
1 REPLY
Ok, I think I can answer myself and leave this here just in case it's useful to someone else.
This JSL does the trick:
obj=Window("DOE- Custom Design");
min runs = obj["Design Generation"][number col box(1)][1];
