sornasst
Assigning Column Name (x) output to a matrix?
As part of a longer script, I would like to extract the column names from one table and list those in a new table in a new column.
I have naively tried the following:
dt = Current Data Table ();
m = [];
For(i=8,i<= N Col (dt),i++,
m = m || Column Name ( i );
New Table ("Table", New Column ("Headers", character,set values(m)));
I get a error message "Concatenate for Strings or Matrices Only" which make sense since I'm trying to stick a Name into a Matrix.
What is the proper syntax and/or function to make this work?
Thank you.
Jeff_Perkinson
Re: Assigning Column Name (x) output to a matrix?
Use a List instead a Matrix​, and then use the Insert Into() function.
m = {};
insert into(m,  Column Name ( i ));
The For() loop may be inefficient for large data tables. In that case a modification of txnelson​'s solution may be better. This version indexes the list returned by Get Column Names to use the items from 8 to the end.
Names Default to Here(1);
dt = Current Data Table();
dt2 = New Table( "Table",
New Column( "Headers",
character,
values( (dt << get column names)[8 :: N Items( dt << get column names )] )
-Jeff
I believe this makes it a little simpler
dt2 = New Table("Table",New Column("Headers", character, values(dt<<get column names)));
sornasst
Hi Jim,
Thank you for your elegant suggestion.
While your script captures all the column names from one file, I would like to be able to skip the first 8 columns to only capture the names of the columns on which I'm computing some stats.
Thank you for your help.
Sincerely,
Thierry
Jeff_Perkinson
m = {};
character,
-Jeff
