BookmarkSubscribeRSS Feed
palermor
Community Member
Oct 15, 2015
Are there compatibility issues for Jmp 12 and OS X El Capitan?
The title says it all.  Or is there an expectation of an upcoming release of a Jmp 13 next year that will have accounted for the new OS?
7 REPLIES 7
KarenC
Feb 10, 2013
Re: Are there compatibility issues for Jmp 12 and OS X El Capitan?
I have had no issues with JMP12 running on El Capitan.
Jeff_Perkinson
Community Manager
Jun 23, 2011
JMP 12 works relatively well on El Capitan but we have found a few issues, including one crash.
Avoid using the new Split View with JMP 12.0 and 12.1. It will cause a crash.
We're working on the next maintenance release and we hope to fully support El Capitan with 12.2.
-Jeff
-Jeff
KarenC
Feb 10, 2013
So if you have no idea that there was a split view in El Capitan you are good to go.
saitcopuroglu
Sep 29, 2014
I am getting 8-10 crash a week (all reported to technical team) mostly during complex tabulate works.
One major thing I noticed over Yosemite is:
When running an outer jsl which creates/concatenates/joins/summarize many many tables to produce a final report, I was able to watch each new data table being created and the final report at the end. By El Capitan nothing/no process is visible, JMP waits waits waits and at the end all those data tables and final report blow up which is not favoured by me...
giovannicerrano
Nov 25, 2015
Hello everybody, i have some problems on my Jmp every time i try to go ahead with a cluster analysis it crashes...
Could you please tell me a way to solve this problem??
Thanks
Jeff_Perkinson
Community Manager
Jun 23, 2011
giovannicerrano10​,
I'm sorry that you're having difficulty.
Crashes like this are best addressed by sending details to Technical Support.
They are in the best position to help you.
-Jeff
-Jeff
giovannicerrano
Nov 25, 2015
Thank you very much!!!
Greetings
-Giovanni
