Share your ideas for the JMP Scripting Unsession at Discovery Summit by September 17th. We hope to see you there!
1cooldudeme
Apply formula to new columns based on old columns' data
Hello everyone,
I am completely new to JMP scripting.
I am trying to create a script that will go to each character column in a table, find all its values (PASS, FAIL, etc..), and create new columns suffixed with "_CODED" using assigned values (1, 2, 3, 4, 5) based on the aforementioned ones.
Here's the script I have right now, that works, but only takes into account a single column. Is there a way I can insert a variable in place of that column name so all columns are accounted for?
dt = Data Table("datatable.jmp");
cols = dt << get column names(Character); //List all character columns
For(i = 1, i <= N Items(cols), i++,
    dt << New Column(cols << get name || "_CODED",
        Numeric,
        "Nominal",
        Format("Best", 12),
        Formula(Name Expr(
If(:Name("Level1") == "PASS", 1, If(:Name("Level1") == "FAIL", 2, If(:Name("Level1") == "", 3, If(:Name("Level1") == "NOTTESTED", 4, If(:Name("Level1") == "IGNORE", 5, If(:Name("Level1") == "PASS|PASS", 6, If(:Name("Level1") == "IGNORE|IGNORE", 7, If(:Name("Level1") == "NOTTESTED|NOTTESTED", 8))))))))
Basically, I'd like to know if there is a way to have the script go through with each Character column in a table instead of only Level 1​. I have tried to use cols ​as a variable in place of Level 1​, but this caused the script to not run because quotation marks were needed, or the script would look for a column named "Level 1", which is not the objective.
I took pieces of other scripts and tried to apply them to this one, so please also let me know if there is anything redundant. Thanks a lot.
pmroz
Re: Apply formula to new columns based on old columns' data
This will do it:
New Table( "Example", Add Rows( 6 ),
     New Column( "aaa", Character, Nominal,
           Set Values( {"PASS", "PASS", "FAIL", "IGNORE", "", "IGNORE"} )
     New Column( "bbb", Character, Nominal,
           Set Values( {"PASS|PASS", "IGNORE|IGNORE", "PASS", "", "FAIL", "FAIL"} )
dt = Data Table("Example");
For (i = 1, i <= N Items(cols), i++,
     one_col   = cols[i] << get name;
     coded_col = one_col || "_CODED";
     col_expr = evalinsert(
"\[   dt << New Column("^coded_col^", Numeric, "Nominal",
Format("Best", 12), Formula(
                if (:name("^one_col^") == "PASS", 1,
                     :name("^one_col^") == "FAIL", 2,
                     :name("^one_col^") == "", 3,
                     :name("^one_col^") == "NOTTESTED", 4,
                     :name("^one_col^") == "IGNORE", 5,
                     :name("^one_col^") == "PASS|PASS", 6,
                     :name("^one_col^") == "IGNORE|IGNORE", 7,
                     :Name("^one_col^") == "NOTTESTED|NOTTESTED", 8;
    eval(parse(col_expr))
pmroz
This will do it:
1cooldudeme
Thanks a lot, it works!
Article Labels
