Pearl
Application builder - Check box to default on
I'm using the Application Builder. I added a Check Box and I wonder how to set to on by default so when I press Run Application the Check Box is already checked.
Thank you,
David
pauldeen
Re: Application builder - Check box to default on
Try this:
CheckBox1 << set(1, 1);
CheckBox1 << set(2, 1);
Screen Shot 2019-06-18 at 19.08.17.pngScreen Shot 2019-06-18 at 19.08.24.png
pauldeen
Try this:
Pearl
Thank you very much pauldeen. This will be of great help in the future.
