The World Statistics Day celebration continues here in the Community. We all need reliable data for sound decision making. Do you have a data source that you trust most? Head over to Discussions to tell us about it.
abdulj
Application Builder - Global Functions?
I'm writing a new add-in using the application builder that has several modules. Looking through the documentation it seems that i should be able to define a Function in Module A and call it in Module B. Everytime i do this i get errors.
Is there anything in particular i need to do to enable this? Right now my code is a bit clunky since i have similar funcitons spread out all over the place as a stop gap measure.
thanks
Re: Application Builder - Global Functions?
It's possible to call between modules, but not the recommended way to define a function that is "global" to the Application.  A module can be instanced more than one time, which means that you would have to query one of the instances to get access to the variables in its namespace.
The best way to define globals for your App is to define them in the Application namespace, which is visible to all module instances:
Article Labels
