We’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
lilysecret
Appending the "SPSS Name" property problem
I'm trying to append the "SPSS Name" property for all columns in my dataset with the string "_R1". This loop works until line 5; the result is that all the SPSS Names get changed to SNname - not the value of the variable, but the text SNname. I've tried putting it in quotes and I've tried using the Name() function and it still didn't work. I'm hoping someone can tell me the syntax I need to use to get this to work. I've attached an abbrievieted file of my data. Thanks!
For( i = 1, i <= N Cols( dt ), i++,
	cName = Column(dt,i) << Get Property("SPSS Name");
	SNname = cName|| "_R1";
	show(SNname);
	Column( dt, i ) << Set Property("SPSS Name", SNname );
cwillden
Re: Appending the "SPSS Name" property problem
Set Property() is not going to evaluate SName.  You probably need to parse SName before evaluating that line.  Try this:
Eval(Parse(Eval Insert("\[Column( dt, i ) << Set Property("SPSS Name", ^SNname^ )]\")));
-- Cameron Willden
cwillden
-- Cameron Willden
You need to perform an eval() on the variable SName.
	show(SNname);
	Column( dt, i ) << Set Property("SPSS Name", eval(SNname) );
cwillden
This is more elegant.  Nice add Jim.
-- Cameron Willden
