Yngeinstn
Append an Open Window after a selection is made
I have been searching for a solution to be able to append an open window after a selection is made from from a calendar box.
Once the Start Date and End Date are selected I would like to open another box right below the panel box that holds the calendar(s)
Below is an example i am trying in the simplfied version. In my actual application I would like to open a check box() list based on the dates selected from a database that was based on an sql script..
Thank You
nw = New Window( "Example", V List Box( pb = Panel Box( "Calendar", V List Box( H List Box( Panel Box( "Select Start", StartDate = Calendar Box( << Set Function( Function( {f1}, sqlstartA = StartDate << Get Date(); ) ) ) ), // End StartDate Calendar Box Panel Box( "Select End", EndDate = Calendar Box( << Set Function( Function( {f2}, sqlendA = EndDate << Get Date(); ) ) ) ) // End EndDate Calendar Box ), H List Box( bb1 = Button Box( "Set Dates", sqlstart = format(sqlstartA, "yyyy-mm-dd"); sqlend = format(sqlendA, "yyyy-mm-dd"); show(sqlstart, sqlend); ), bb2 = Button Box( "Cancel" ) ), Wait( 0.1 ), pb << Append( Text Box( "Why isn't this working" ) ) ) ) ) );
ian_jmp
Re: Append an Open Window after a selection is made
Working in a hurry, I'm not sure what I did to your original. But the code below does indeed work. Generally I find it helps readability and maintainability to define actions as expressions with a name, then invoke them using that name.
	V List Box(
			V List Box(
				H List Box(
							<<Set Function( Function( {f1}, sqlstartA = StartDate << Get Date() ) )
							<<Set Function( Function( {f2}, sqlendA = EndDate << Get Date() ) )
				H List Box(
					bb1 = Button Box( "Set Dates", pb << Append(Text Box( "Why isn't this working" ))),
ian_jmp
	V List Box(
			V List Box(
				H List Box(
				H List Box(
Yngeinstn
That is crazy because it wasn't working... Thank you for pointing that out
Yngeinstn
Allow me to expand on that if I may.
Now that you got that to work with a text box the actual solution i am trying to solve is placing a check box that gets populated when you push Set Dates. I tried to insert LotListBox = Check Box( LotList, doListChoice ); in place of the Text Box() and i am only getting the panel window..
From what i can gather the the last 4 sets of script isn't executing therefore just sending an empty window.
/* Calendar Box to Select Start and End Dates				  */
	V List Box(
			V List Box(
				H List Box(
							<<Set Function(
								Function(
									{f1},
							<<Set Function(
								Function(
					dtLotList;// End EndDate Calendar Box
				H List Box(
						pb << Append(
							Panel Box( " ",
								V List Box(
									Text Box( "Select Wafer(s)" )
								LotListBox = Check Box( LotList, doListChoice ) // Pulls from the Database basedd on the dates selected above
// SQL Code that brings in the entire wafer list from database
SQLcode = Expr(
	SELECT DISTINCT
		t1.wafer_number,
		t1.testdate
	FROM tst_master  t1
		LEFT OUTER JOIN tst_dataset_header t2
			ON  ( t2.run_id = t1.run_id )
	WHERE t1.testdate >= ' " || sqlstart || " '
		AND t1.testdate <= ' " || sqlend || " '
		AND (t1.wafer_number NOT RLIKE '-ATL' )
		ORDER BY t1.testdate DESC
/* Brings in the list of wafers from the SQL Query	 		                 */
/* Opens Database based on Calendar Dates and Lists Lots	  */
// Tried to put this in an expression to execute in the main window
dtLotList = Expr(
dt_LotList = Open Database(  <Database String>, SQLcode, "LotList" );
Summarize( LotList = By( :wafer_number ) );
Close( dt_lotlist, No Save );
// Original script to bring in a list of wafers within the date range
/* Lists Lot List in Check Box Format						  */
// This is what i would like to be appended in the first window
/* Allows for Multiple Lots to be Selected					  */
doListChoice = Expr(
	SelectedLot = LotListBox << get selected; //get the selected items
	If( N Items( SelectedLot ) > 0, //run through each selected item if there are any
		For( i = 1, i <= N Items( SelectedLot ), i++,
			Print( SelectedLot[i] )
	LotListSQLString = "";
		LotListSQLString = LotListSQLString || "'" || Char( SelectedLot[i] );
		If( i == N Items( SelectedLot ),
			LotListSQLString = LotListSQLString || "'",
			LotListSQLString = LotListSQLString || "',"
	Show( SelectedLot );
ian_jmp
Of course I don't have your DB. But, making corresponding simplifications to your code, this shows the mechanics of adding the check box to the UI.
	V List Box(
			V List Box(
				H List Box(
					Panel Box( "Select Start", StartDate = Calendar Box( <<Set Function( Function( {f1}, sqlstartA = StartDate << Get Date() ) ) ) ), 	// End StartDate Calendar Box
					Panel Box( "Select End", EndDate = Calendar Box( <<Set Function( Function( {f2}, sqlendA = EndDate << Get Date() ) ) ) ) 			// End EndDate Calendar Box
				H List Box(
					bb1 = Button Box( "Set Dates", pb << Append( Panel Box( "Select Wafer(s)", LotListBox = Check Box( LotList, Beep() ) ) ) ),
LotList = {"A", "B", "C"};
Yngeinstn
Thank you very much.. I was trying a Wait() in between that part of the
code.. When i was reading the forums i saw something about Pause before
executing a script and saw the beep() however i didn't even think about
putting that in there..
Thanks you very much again..
