BookmarkSubscribeRSS Feed
Any way to sort the column names in the oneway graphs?
Hi Guys,
Is there any way you can sort the column names in the Select Columns window of the oneway Distribution? I have multiple columns and some are continuous numeric and others are character,nominal and I have to manually select the continuous numeric columns to the Y response box.
Thanks.
Re: Any way to sort the column names in the oneway graphs?
Ok. Got it. I reordered the columns in my data table by data type and was able to see the same order in my Select Columns window.
