BookmarkSubscribe
TheSource
Analyze > Modeling > Nonlinear - Model Library Won't Open
I am having difficulty opening the nonlinear model library. When I open nonlinear dialog window and click the button labeled "Model Library", nothing happens. Opening the jmp log, I find that upon clicking the button, the script invocation generates the error:
ERROR: Unrecognized boolean value in access or evaluation of 'true' , true/*###*
I copied the code from the log file into a new temporary script so I could run the debugger, and I found that it is complaining about the first line:
Names Default To Here( true );
By changing this line to:
And running my script (again, copied from the log file) from ../Resources/Builtins I can run my hacked nonlinear analysis window manually with broken/default button text. Surely there is a root cause and real fix to this problem though. Can anyone help pinpoint what it could be?
I am running JMP Pro 12.2.0 (x64) on Windows 8.1 Enterprise (x64)
Byron_JMP
Re: Analyze > Modeling > Nonlinear - Model Library Won't Open
there is something weird going on, check in with support@jmp.com.
also, find your license administrator and get a version update.
Theres a lot of new stuff since v12 in JMP Pro, and there were some calculation updates to make things faster too. current version is 14
JMP Systems Engineer, Pharm and BioPharm Sciences
