jennym
Community Member
Analysis of Variance & Principal Component Models
Hello!
I am new to JMP Pro (JMP Pro9 on a Mac), and I am looking for an analysis of variance model to compare surveys (three surveys for the same set of people).  Can anyone recommend one for me?
Additionally, I am looking for a principal component model to analyze the survey questions / responses to see if there is correlations.  Again, can anyone recommend a file for me to use?
Thank you in advance so very much!
XanGregg
Re: Analysis of Variance & Principal Component Models
I don't know which analysis is best for you (I'm not a statistician anyway), but you should try the Statistics Index and the Scripting Index under the Help menu. The former, especially, is good for translating terminology. For instance, analysis of variance is found in Fit Y by X and Fit Model in JMP.
