BookmarkSubscribeRSS Feed
gutloja
Jul 31, 2015
Align rows in database based on specified sequence
[Sort rows based on a given sequence in another column]
Hello, All.
I have a database [sample attached] that is stamped with series of date and time:
For example:
02/24/2015 6:00PM [Followed by about 50 columns of data that correspond to this date/time]
02/24/2015 6:00PM
[100 rows with similar time, but seconds apart]
02/24/2015 7:00PM [Followed by about 50 columns of data that correspond to this date/time]
02/24/2015 7:00PM
The database includes months at the time [a few data series included in the attached file].
Some files have missing data and some of the data series are incomplete [Labeled rows in attached sample].
Question: is there a way to sort or "align" the database using an artificial date/time column series created with a sequence [Sequence( 3505335300, 9905335300, 900, 55 )].
I want to be able to see the gaps in the database [similar to the attached sample data].
I was thinking of inserting a column with the artificial date/time, and then a function to insert rows for all columns [except where the artificial date/time is] if the artificial and real date/time stamp do not align. But I am not sure how to do that.
Any help will be very appreciated!
Thank you,
-Jose GL
ron_horne
Jun 23, 2011
Re: Align rows in database based on specified sequence
hi gutloja​,
if i understand your question correctly there were similar discussions here in the past just with different terminology. try the following links:
bubble plots - unequal time intervals
How do I place values into data table cells using JSL
Joining tables with different levels of precision
ron
