BookmarkSubscribeRSS Feed
Adding weight to component principals for a HCA
Hi everybody !
I would like to know how it's possible to add the weights of each component principals (eigen values) for the HCA. In fact, i would like to perform a Hierarchical Clustering Analysis on 6 components principales (from the CPA) but i don't find the option to add each weight to its principal component. It's possible in other software such as Excel Stat. It's possible to select a small column where the different weights appear.
Thank you in advance for your help !
See ya !
