bbass
Adding variable column names based on date
I want to create a script that adds multiple columns with the column names based on the date.  For example, taking today's date "3/4/2020" and adding 3 additional columns whose names correspond to the previous 3 weeks; giving the result of:
Column 1: "3/4/2020"
Column 2: "2/26/2020"
Column 3: "2/19/2020"
Column 4: "2/12/2020"
Re: Adding variable column names based on date
Here is a real simple way to do this.  It takes the first column in the data table and sets it equal to today's date, and then on the next three columns it sets to dates 1,2,& 3 weeks before
dt = Current Data Table();
Column( 1 ) << set name( Format( Today(), "m/d/y" ) );
Column( 2 ) << set name( Format( Today() - In Weeks( 1 ), "m/d/y" ) );
Column( 3 ) << set name( Format( Today() - In Weeks( 2 ), "m/d/y" ) );
Column( 4 ) << set name( Format( Today() - In Weeks( 3 ), "m/d/y" ) );
bbass
That worked.  Thanks!
