News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
wjalford
Adding sql data to an existing data table
I have an existing data table and I want to run a sql query to pull in new data and add it to my existing jmp data table via J script.  Does anyone have an example?
GM
GM
Re: Adding sql data to an existing data table
Have you had a chance to look in the Scripting Index?  You may be able to find and example of what you need.  The Scripting Index is an item under the Help Menu in JMP.  Hope this helps.
