BookmarkSubscribeRSS Feed
Adding spec. limits and units to columns
Hi Guys,
I am taking limits and units from another file and storing them in variables. Then I am trying to set the limits and the units for columns of another table. Here is what I am doing:
Re: Adding spec. limits and units to columns
Ok got it. I used the following:
mpb
Jun 23, 2011
With the help of the Jump into JMP Scripting book I constructed the following example which seems to work. (I recommend that book for lots of examples of how to do things in scripting).
It assumes you have the Fitness data open and another table with 5 columns called "MyFit" (I just repeated the Oxy column 5 times),
