ENTHU
Adding note below tabulate
I need to add some note(text) below tabulate.Tried used outline box and text box but was not able to get it in the right position.
How can I do this?
Thanks
Re: Adding note below tabulate
Can you share the Tabulate platform that you made?
Can you tell us what you tried already that gave an unsatisfactory result?
Can you tell us where you want the text box?
ENTHU
I won't be able to reveal the table. But I have graph window and tabulate on the side.
Need to be able to add note below this table.
What I tried : outline box = ("ABC",
tb =  ("required text"));
This does display the output but it is not below the tabulate but is below the graph.
So basically the question is if there is a way to control the position of the textbox.
Thanks
Here is an example of what I think you want:
tab = dt << Tabulate(
	Show Control Panel( 0 ),
	Add Table(
		Column Table( Analysis Columns( :height ), Statistics( Mean, Std Dev ) ),
		Column Table( Analysis Columns( :weight ), Statistics( Mean, Std Dev ) ),
		Row Table( Grouping Columns( :sex ) )
Report( tab )[Outline Box( 1 )] << append( Text Box( "This is the text" ) );
