samir
Adding labels to Graph Builder heat map
I wanted to add labels to heat maps and I found the answer in the following link:
Re: Adding labels to Graph Builder heat map
However, I faced an issue:
I see that the labels are not centered in their own rectangles. is there a way to do so ?
Please find attached a data table containing a script that illustrates my problem.
Thanks a lot
