avner8943
Adding graph to JMP application or new window disable MakeRowStateHandler
Hi, I have a script that using Local Data Filter in Graph Builder object. I wrote a function that draws a different line in the chart when I switch selection in the local data filter. It's working fine in the Graph Builder window, but if I try to put in a new window or into JMP app, it ignores the function and does not draw the line.
Anybody knows why?
Edit:  I joined my code.
gb = dt << Graph Builder(
	Size( 865, 775 ),
	Fit to Window( "Off" ),
	Variables( X( :TIME_col ), X( :col2 ), Y( :col1 ), Y( :col2 ), Group X( :group_leg ), Overlay( :leg_col ) ),
	Elements( Position( 1, 1 ), Points( X, Y, Legend( 36 ) ), Smoother( X, Y, Legend( 48 ) ) ),
	Elements( Position( 1, 2 ), Points( X, Y, Legend( 38 ) ), Smoother( X, Y, Legend( 49 ) ) ),
	Elements( Position( 2, 1 ), Points( X, Y, Legend( 40 ) ), Line Of Fit( X, Y, Legend( 24 ), R²( 1 ) ) ),
	Elements( Position( 2, 2 ), Points( X, Y, Legend( 42 ) ), Smoother( X, Y, Legend( 51 ) ) ),
ldf = gb << Local Data Filter(
	Add Filter(
		columns( :leg_col, :group_col ),
		Display( :leg_col, Size( 160, 60 ), List Display ),
		Display( :group_col, Size( 160, 60 ), List Display ),
		Order By Count( :group_col )
cso1 = gb << Column Switcher( :leg_col, legend_cls ); // legend_cls  is list of cols
cso2 = gb << Column Switcher( :col1, num_cls ); // num_cls is list of cols
cso3 = gb << Column Switcher( :col2, num_cls );
cso4 = gb << Column Switcher( :TIME_col, time_cls );// time_cls is list of cols
cso1 << Set Size( 200 );
cso1 << Set NLines( 6 );
cso2 << Set Size( 200 );
cso2 << Set NLines( 15 );
cso3 << Set Size( 200 );
cso3 << Set NLines( 15 );
cso4 << Set Size( 200 );
cso4 << Set NLines( 10 );
// Row state handler function
doSomethingWithSelection = Function( {x},
	{Default Local},
	currentScript = ldf << getScript;
	Clear Log();
	str = Char( Name Expr( currentScript ) );
	prodi = Left( Substr( str, Contains( str, "Where(:Prod == " ) + 16 ), 4 );
	response = cso2 << Get current;
	predictor = cso3 << Get Current;
      // dt_lims is data table of control limits
	TR1_row = dt_lims << get rows where( :Label == response & :Prod == prodi );
	::TR_res = Column( dt_lims, "CL" )[TR1_row];
	Try( gbreport[FrameBox( 1 )] << Add Graphics Script( H Line( TR_res ) ) );
	TR2_row = dt_lims << get rows where( :Label == predictor & :Prod == prodi );
	::TR_pred = Column( dt_lims, "CL" )[TR2_row];
	Show( TR_pred );
	Try( gbreport[FrameBox( 2 )] << Add Graphics Script( H Line( TR_pred ) ) );
// Get a reference to the report
gbReport = Report( gb );
// Assign the row state handler to the local data filter display box
rsh1 = gbReport[Outline Box( 1 )] << MakeRowStateHandler( doSomethingWithSelection );
Re: Adding graph to JMP application or new window disable MakeRowStateHandler
My guess would be that you are using a relative reference to the Frame Box(), and when it incapsulated into an additional object (New Window), the reference is no longer valid.
Other things may be going on, so it would be very helpful if you could provide more specifics of you code, or even better yet, the code itself.
avner8943
Added the script
Article Labels
