BookmarkSubscribeRSS Feed
asvp
Jun 23, 2011
Adding Regression estimates to data table
Hi all,
What changes do I need to make to the below JMP script to add "estimates"(Intercept and slope) to the data table?
Thanks,
ASVP
dt = open("rawdata.jmp");
obj = Fit Model(
    Y( :OUTPUT ),
    Effects( :INPUT ),
    Personality( Standard Least Squares ),
    Emphasis( Minimal Report ),
    By( :TYPE ),
    Run
ms
Jun 23, 2011
Solution
When using the By() property the message <<make combined data table is convenient.
For your example the commands below should yield a new table with the parameter estimates and accociated statistics.
robj = obj << report;
robj[1]["Parameter Estimates"][1] << make combined data table;
ms
Jun 23, 2011
Solution
asvp
Jun 23, 2011
Hi MS,
This is exactly what I was looking for, thanks for your help.
Regards,
ASVP
