shoffmeister
Addin an image to the report of Add-In
Hi JMP-gurus!
While working on my Add-In I am facing the following problem: One of my reports uses a bitmap which I added in the addin-builder as ""Additional File". After installing the add-in everything seems to work.
But after a while I'll get the error:
Error with file: Path is invalid: \all.png.
in the log when running the function.
Sadly I could not figure out when exactly this happens. Any ideas how JMP can "forget" where the image is? Or what would be the right way to add a bitmap as a resource to an add-in?
Regards,
Sebastian
pmroz
Re: Addin an image to the report of Add-In
Sebastian,
I would make the path explicit.  You can store the bitmap in your addin location.  For example suppose the "alias" for your addin is com.mycompany.test_addin.  Then you could simply refer to the file using $ADDIN_HOME:
"$ADDIN_HOME(com.mycompany.test_addin)\all.png";
pmroz
Sebastian,
shoffmeister
Thanks a lot. Currently it works. :-)
