avner8943
Add ref line and column switcher
Hi all,
I have two questions:
1) when I switch column with column switcher, I can't add ref line anymore. for example
obj = dt << Bivariate( Y( :height ), X( :weight ) );
ColumnSwitcherObject = obj << Column Switcher( :height, {:name, :age, :sex, :height} );
gbReport = obj << report;
axisbox = gbReport[axis box( 1)];
now when I run the next line
axisbox << Add Ref Line(60, "Dotted", yellow, "TR", 2 );
But if run this two lines
ColumnSwitcherObject << set current("age"); axisbox << Add Ref Line(14, "Dotted", yellow, "TR", 2 );
It giving me this error
deleted object reference: axisbox << Add Ref Line(14, "Dotted", yellow, "TR", 2) in access or evaluation of 'Send' , axisbox <<  /*###*/Add Ref Line( 14, "Dotted", yellow, "TR", 2 ) /*###*/
In the following script, error marked by /*###*/
2) Is there a way to execute a script when switching columns in column switcher? Something like "makerowstatehandler" when we use local data filter?
Thanks.
Re: Add ref line and column switcher
For #1, you need to re-run the line that sets the AxisBox variable first. This is because the Column Switcher in JMP re-generates the report when the column changes, so the old references to the report and axis box are no longer valid.
// Always needs to happen in this order
axisbox = gbReport[axis box( 1 )];
For #2, I do not believe there is an equivalent handler for Column Switcher like there is for the Data Filter. This might be a good idea for the JMP Wish List.
Justin
avner8943
Thanks,
But it's showing me this error
axisbox << Add Ref Line( 14, "Dotted", yellow, "TR", 2 );
and not displaying the line
The column switcher has the habit to drop its reference when a column is swapped out.  By either embedding the reference line into the code
Bivariate(
	Y( :height ),
	X( :weight ),
		Dispatch(
			"2",
			ScaleBox,
			{Add Ref Line( 62.9375, "Dashed", "Yellow", "TR", 1 )}
or adding the code by using
<<add graphics script
I believe you can get around the issue
or
