AWMN
Add-in makes JMP really slow at booting
Hi all.
So, I have this script that I made using the appbuilder. I've tried to make an add-in that can be installed, by choosing 'save script - to addin. When I do this, JMP spends a long time compiling it. It also takes forever to install, and once installed, booting JMP is extremely slow. To the point, where I cannot have the addin installed. Any suggestions on the reason for this?
Im using JMP 14
Br. Anders
AWMN
Re: Add-in makes JMP really slow at booting
Found a solution. If the code is too long, it seems it needs to be imbeded as a .jsl file that is being called, rather than having the code itself within the addin
