mysteriouskrypt
Add a Custom Button or Embed Data Filter into Custom UI
Is it possible to add a custom button to the Data Filter that I can use to create a subset data table for the selected data? Alternatively, is there a way to embed the Data Filter into my existing UI so I can include buttons and other controls in a unified interface, rather than having the Data Filter appear as a separate window?
I don't want to reinvent the wheel by implementing the conditional filtering that Data filter provides already.
Thanks in advance!
mmarchandFSLR
Re: Add a Custom Button or Embed Data Filter into Custom UI
You can add a Data Filter Context Box to your UI and contain the Data Filter in there.
mysteriouskrypt
Thank you.
If you have JMP19, you might want to take a look at Filter Views
Using JMP > JMP Reports > The Data Filter > Filter Views
hogi
Level XIII
In this year's Discovery Summit, there is a talk by @Mandy_Chambers about  Filtered Views in JMP 19 .
The Filter View framework is a wonderful enhancement of the data grid - and it allows highly versatile selection subsetting.
Take a look at the Quickselect Toolbar in the Marketplace. The latest version adds a drill-down option based on the new framework:
(view in My Videos)
mysteriouskrypt
Thanks
