tom_abramov
Level V
Add Favorites to Data Filter with Eval(Substitute(Expr
I have a bug with adding Favorites to Data Filter.
I would like that FAVORITECLAUSE will not be a string but expression (more convenient to maitain).
Please assist.
FAVORITESCLAUSE = Favorites(
	"FAV1"(Match( columns( :age, :sex, :height ),
		Where( :age == 14 ), Where( :sex == "M" ),
		Where( :height >= 51 & :height <= 60.952 )
	"FAV2"(Match( columns( :age, :sex, :height ),
		Where( :age == 14 ), Where( :sex == "F" ),
Eval(
	Substitute(
			Expr(
				dt << Data Filter(
					Location( {-1136, 147} ),
					Add Filter(
						Display( :age, Size( 178, 102 ), Height( 102 ) )
					_FAVORITESCLAUSE_
		Expr( _FAVORITESCLAUSE_ ), FAVORITESCLAUSE
ih
ih
Re: Add Favorites to Data Filter with Eval(Substitute(Expr
Try wrapping your FAVORITESCLAUSE in Expr() so it doesn't evaluate immediately, and then use Name Expr() when substituting it in order to add the expression defined by FAVORITESCLAUSE without evaluating it.
FAVORITESCLAUSE = Expr( Favorites(
Eval(
	Substitute(
			Expr(
				dt << Data Filter(
					Add Filter(
					_FAVORITESCLAUSE_
		Expr( _FAVORITESCLAUSE_ ) , Name Expr( FAVORITESCLAUSE )
ih
ih
Eval(
	Substitute(
			Expr(
				dt << Data Filter(
					Add Filter(
					_FAVORITESCLAUSE_
tom_abramov
Level V
Thank you!
