BookmarkSubscribeRSS Feed
bholmes91011
Jun 12, 2012
Add Error Bars to XBar Control Chart
For my research group I have been tasked with generating a control chart that shows the mean value for a process over time, and includes error bars (as standard deviation of the x individual datapoints used to determine the mean value). I have found the following script that other community members have posted in other discussions, but since I am VERY GREEN at JSL scripting I don't know how to incorporate into string values - or if its even possible? I really hope there is a way to do this using JSL, otherwise I have to resort to Excel and do a TON of inefficient, time consuming steps to do everything that Jmp can via JSL (ie. mark by column, color by column, add reference lines, automation of analysis, etc....)
// Add columns with Mean ± SE
New Column( "lower", numeric,
    values(
        (:Name( "Water Content wt%" ) << get as matrix) –
        (:Name( "stdev wt%" ) << get as matrix)
New Column( "upper",
    numeric,
    values(
        (:Name( "Water Content wt%" ) << get as matrix) +
// Generate chart using Graph Builder platform
Graph Builder(
    Show Control Panel( 0 ),
    Variables(
        X( :Date of Analysis ),
        Y( :lower ),
        Y( :upper, Position( 1 ) ),
        Y( :Name( "Water Content wt%" ), Position( 1 ) )
    Elements(
        Bar(
            X,
            Y( 1 ),
            Y( 2 ),
            Y( 3 ),
            Legend( 2 ),
            Bar Style( "Interval" ),
            Summary Statistic( "Mean" )
        Line( X, Y( 3 ), Legend( 4 ), Row order( 0 ), Summary Statistic( "Mean" ) )
        Dispatch(
            "400",
            ScaleBox,
            {Legend Model(
                2,
                Properties( 0, {Line Color( 0 )} ),
                Properties( 1, {Line Color( 0 ), Marker( "FilledCircle" )} )
        Dispatch( {}, "Graph Builder", FrameBox, {Marker Size( 3 )} )
bill
Community Member
Jun 23, 2011
Re: Add Error Bars to XBar Control Chart
Might boxcharts be an option for you?
bholmes91011
Jun 12, 2012
Perhaps, but I would still need to be able to use XBar, IR chart functionality. Which, I assume is not possible with BoxPlot? I am very new to this, was kind of thrown into the ocean without knowing how to swim properly
