d_barnett
Accessing Realtime Sensor Directly via USB
There were a number of examples where JMP analyses sensor data (using FDE) successfully but I'm looking for an example where the data is collated directly into JMP and not via a db/spreadsheet etc.
E.g. a temperature sensor connected via USB.
Has this been done or any ideas if this is possible?
David
Re: Accessing Realtime Sensor Directly via USB
There is documentation on "Real-Time Data Capure on Windows" in the Scripting Guide
     Help==>Scripting Guide
Look into the section on Extending JMP
