James_Kim
About formula : "How many (categorical data) by column ?
Hi there~
Could you do me a favor?
I want to know
without calculation of repeated data?
for example
Open( "$SAMPLE_DATA/Big Class.jmp" );
I want to know how many (:age) types by (:sex)?
I want to know that function by using formula only
ms
Super User ms
Re: About formula : "How many (categorical data) by column ?
Oh, I forgot that Col Number() only works for numeric columns as first argument.
Here two suggestion for a column formula solution (and not by JSL-script ):
Use a numeric column that's known to not have any missing values, e.g.
Col Number( :TRANS_TIME, :DVC )
Or if each DVC data always ends with a unique four digit number (as in the posted table) this would give the same result:
Col Number( Num( Right( :DVC, 4 ) ), :DVC )
ms
Super User ms
Use this Statistical function:
Col Number( :age, :sex )
The second argument is the By-bariable. In formula editor the optional second argument (and third etc) is activated by selecting the first argument and clicking on ^ (insert).
James_Kim
Dear MS,
I really appreciate with ur idea.
But I still cannot solve this problem.
b'cus my data is a little bit more complicate.
There are repeated same data in the "name" column,
.. therefore...  Col Number( :age, :sex ) is not working..
This is actual sample..
when I use this
Col Number(:LOT_ID, :DVC)
but it is not working,,, the result shows "0" only  like as below.
I think ... it is because of the same data in 'LOT_ID' column
but i still want to calculate it.
I soIve it, by using other column data "time"  like as below.
Col Sum(If(Col Minimum(:TRANS_TIME, :LOT_ID) == :TRANS_TIME, 1, 0), :DVC)
But I still want to solve it    without the other data.
Could you give me  the other idea?  I need ur help.. MS
ms
Super User ms
James_Kim
Oh~ MS~!
I truly appreciate you taking the time to answer my questions!
I hope I have a chance to help you, someday.
Have a good day! thanks.
