uday_guntupalli
Level VIII
API Response Encoded as Gzip
All,
  I am tapping an internal API and the expected response of the API endpoint is an Excel File. However, when I try to  use HTTP request, I receive a response. I am assuming the response is encoded, but I wonder what is a good way to extract the data and use it.
 The request I make to the endpoint is as follows:
HeaderStr = "Authorization: Bearer " || AccessToken;
Request = New HTTP Request(
			    URL( URLDes ),
		            Method( "Get" ),
			    Headers( {HeaderStr} )
			  ) << Send;
The response I receive is :
"PK"
Best
Uday
Craige_Hales
Staff (Retired)
Re: API Response Encoded as Gzip
Not sure how to get a blob back from <<send, but <<download puts the binary data in a file:
request = New HTTP Request(
    URL(
        "http://drawoutside.com/abc123.xlsx"
    Method( "Get" )
request<<download("$temp/z.xlsx");
open("$temp/z.xlsx");
JMP's open function imported the xlsx fileJMP's open function imported the xlsx file
@bryan_boone
Craige
15 REPLIES 15
Craige_Hales
Staff (Retired)
"PK" is the signature for .zip files. If the data was received in a blob (text won't have the binary data) you can use JMP's zip archive object to open it, something like this (not at work right now...)
za = open(blob,"zip");
za<<members
za<<open(member)
(best look in the scripting index.)
Craige
Craige_Hales
Staff (Retired)
Actually, excel files probably are zip files, with an xlsx extension. You might already have exactly what you expect.
Craige
uday_guntupalli
Level VIII
@Craige_Hales,
        Appreciate you trying to guide me when not at work. Let's try tomorrow when you are back. But, here is what I did:
image.pngIf the response was indeed a zip file, then this didn't work. I think it is an excel file, because I was able to use WriteBin command and content command in R to write it out as an Excel file. However, I have no clue how to capture it in JMP.
Additonally, I also tried this :
image.pngThis also results in an error :
Error with file: Path is invalid: \PK.
Best
Uday
Craige_Hales
Staff (Retired)
    URL(
    Method( "Get" )
@bryan_boone
Craige
uday_guntupalli
Level VIII
@Craige_Hales
        Thank you Craige. Gets me 95% my way there. I see that the file gets downloaded, but JMP fails to open it  both manually or via script. I tried to intoduce a wait() between the download and open and that didn't help either.
Best
Uday
Jeff_Perkinson
What's the rest of the error message, above the "In the following script..." line?
Are you able to open the downloaded .xlsx file using Excel?
-Jeff
uday_guntupalli
Level VIII
@Jeff_Perkinson,
         Here is the error I receive:
Tried to open: /C:/Users/Test.xlsx
Cannot open table in access or evaluation of 'Open' , Open/*###*/("C:\Users\Test.xlsx")
Best
Uday
Additionally,
What does
request << Get Status Message
show?
That will be the status message from the Web Server (200 is good)
There are:
request << Get Status  // a number
//booleans
request << Is Successful
request << Has Error
request << Has Client Error
request << Has Server Error
request << Has Information
request << Has Redirection
These will let you give information about the connection and the request that was made to the server.
request << Send() will return either a blob or text.
To see what you have call:
request << Get Mime Type();
most of them are covered here:
https://developer.mozilla.org/en-US/docs/Web/HTTP/Basics_of_HTTP/MIME_types/Complete_list_of_MIME_ty...
It is up to the server if they actually add mime type information, but these days, most of them do.
