uday_guntupalli
Level VIII
Re: API Response Encoded as Gzip
@bryan_boone
                 All the messages return the same error . When I try to download the file as @Craige_Hales recommended, it works fine, but none of the diagnostic functions yielded any result     image.png
Best
Uday
What you have in your code is that Request is the result of Send.
I *think* what you want is:
request = New Http Request(
URL( URLDes),
Method("GET"),
Headers({HeaderStr})
); //request is the request object
data = request << Send(); //data is the data returned by the web server
That way you can examine the status of request after you've interacted with the service.
I generally think about HTTP Request stuff in 3 steps
Create
Configure
Send
uday_guntupalli
Level VIII
@bryan_boone,
               Thank you for that.
While this is helpful to some degree, I don't see a way other than downloading the data, to de-compress it and interpret within JMP, is my interpretation correct  or do you have any other approaches ?
Best
Uday
You can still use Download instead of Send.
What the above shows is that you have gotten a complete download from your web service. (which is good)
to use Download instead of Send, you can do this:
filename = request << Download("$temp/Test1.xlsx", "replace"); //file is the filename returned by the web server. replace will replace it.
if( !IsEmpty(filename), //a filename is empty if the download fails
//process your file
In your case, the mimetype is "text/html" and not an excel spreadsheet. You just named it with and xlsx extension.
If your web service has a different endpoint for excel spreadsheets, use that.
or
If your web service uses and "Accept" header to specify an excel spreadsheet, use that
otherwise
Open the file with a text editor to see what it is. (or a browser) According to the mimetype, you downloaded html.
@uday_guntupalli
That's a great usage for having
HTTP Request << Send accept, say, "blob" or "text" arguments.
We'll look into it for JMP 15.  Do you want to add it as a Wish List item?
Thanks
-Bryan
uday_guntupalli
Level VIII
Of Course @bryan_boone. I love to contribute to making JMP better and easier, so it makes our lives easier :) :)
Best
Uday
Article Labels
