BookmarkSubscribe
pcall
ANOVA
Hi could someone please explain how go about this problem?
7 REPLIES 7
Re: ANOVA
The Discussion Forum isn't intended to do homework assignments and this question ceratainly appears to be a homework assignment.
The solution to the problem is an easy thing for JMP to solve.  Documentation for how to do this is covered in
     Help==>Books==>Using JMP
and
     Help==>Books==>Basic Analysis
Re: ANOVA
and
lsuchris15
Community Member
Re: ANOVA
Thanks Jim,
Even thought its not my question, the class is advanced statistics not JMP. There is no class on teaching JMP so its dificult to understand how to get JMP to generate the graphs and statistics needed to answer the problem especially when you've never used the software before.
mjoner
Re: ANOVA
The instructor should be teaching this in lecture if the expectation is for students to be able to do this on homework. If the instructor is not doing this, the student should visit the instructor or the T.A. during office hours.
Re: ANOVA
First the data structure needs to be in an analytical form of
Cotton %,  Tensile Strength
The Distribution Platform will allow you to evaluate such things as the normality
The Fit Y by X Platform will handle the remaining questions
I think the easiest way for you to get familiar with JMP is to go through a couple of the tutorials
     Help==>Tutorials
Re: ANOVA
Another option for learning more about JMP is to go to the You Tube link below and watch some of the videos there.
https://www.youtube.com/user/JMPSoftwareFromSAS
JMP is the SAS software for data visualization and analytics on the desktop. Interactive, comprehensive and highly visual, JMP can help you discover what's hidden in your data. Learn more at jmp.com
Re: ANOVA
Hint: as for using JMP, this common layout of the data needs to change before the analysis - see Tables > Stack.
