cam
cam
ANOVA with multiple columns
Is there any way to have JMP perform an ANOVA test when data is divided by column?  For example, I have individuals' scores in different rounds of a game divided by column according to the person.  I know that I can use a sledgehammer approach and copy-paste the data from each column into a single one and designate each data point as belonging to a specific person with a categorical variable, but is there any way for JMP to simply recognize the different column headings as the categorical variables?
Thanks,
Cam
ms
Super User ms
Re: ANOVA with multiple columns
I think JMP require a variable to be in a single column. However, there is a quick way to stack the data from two or more columns into one column: Stack in the Tables menu.
