BookmarkSubscribeRSS Feed
mujahida
Jan 11, 2014
ANOVA related question
I have following data to implement analysis of variation.
1>. I follow the statistic requirements to check its pre-condition such as normanility, homogerous,
2>. Finding
    a>. it is non normal distribution, what's more, their residuel also is obviously non normal
    b>. they is not homogerous in deviation
I apply some methods to transfer data such as
root squre,
log,
and Fit model> factor profliling> Box-cox transformation, then save the best transformation, all of ways result and check their normality and homogerous,
the result also cannot meet the prequisite of ANOVA
in JMP, what I can do to conduct ANOVA reasonably?
treatment Data
A28
A22
A54
A19
A32
A31
B7
B11
B30
B6
B11
B13
C6
C9
C26
C7
C7
C11
D177
D151
D110
D117
D135
D138
E184
E146
E131
E110
E134
E
141
KarenC
Feb 10, 2013
Re: ANOVA related question
Step 0: Plot your data.
I think you may find that you can answer your questions about your treatments without ANOVA (or any formal statistical tests) from a graph.  Judging normality of your responses is difficult with only 6 data points per group.  You might also look carefully at Treatments A, B, and C as they each have an "unusual" data point.  You might also read up on multiple comparison tests as alternatives to ANOVA (in general).
Peter_Bartell
Jun 5, 2014
I'll also add that before analysis it's helpful if you inform readers a bit about the practical problem you are trying to answer, and the hypothesis you are testing. One could presume the hypothesis you are testing is H0: mu(A)=mu(B)=mu(C)=mu(D)=mu(E)...but unless you tell us...well we're only guessing. Then we'd need to know the stated alpha risk too...before you do any data collection or analysis.
Once you get to analysis...then Karen's step 0 is a must. I shout from the rooftops each and every day, "The three rules for successful data analysis are: Rule 1. Plot the data; Rule 2. Plot the data; Rule 3. Plot the data.
malcolm_moore1
Jul 3, 2014
If you are concerned about the assumptions of oneway ANOVA, then try selecting one of the non-parametric tests such as Wilcoxon from the Oneway hotspot (red triangle) or alternatively try Partition from Analyze > Modeling, this will tell you which levels of your treatment variable result in different response means without making the assumptions of ANOVA.
