hlazar
5 number summary not respecting column format
When using box plots in graph builder, the 5 number summary is not respecting the column format. I have the column format set as Scientific SI and when selecting 5 number summary, the values are still in decimal/auto so that you can not see any values as they are well below zero (10^-6). Please let me know if there is a way to change this.
This is JMP 15.1
Re: 5 number summary not respecting column format
I suggest you pass this to JMP Support
     support@jmp.com
