alexim
New Contributor
2-way ANOVA model results issue
Hi, pls see the images below, the first is the data, the second is the Analysis of Variance from JMP, the 3rd is the output from another tool. Is there a way to list the factors in the Analysis of Variance table?
thanks,
Alexim
Re: 2-way ANOVA model results issue
The information that you want is available in the Effect Tests report. All of the contributions to the Model sum of squares are found in that report.
alexim
New Contributor
The one report that was minimized. Thanks for the speedy reply Mark!
