Speaker | Transcript |
| Hello, my name is Chris Gotwalt |
00 | 08.966 |
| 3 |
| has been developed for variance |
| components models, we we think |
00 | 25.566 |
| 7 |
| statistical process control |
| program, one has to understand |
00 | 40.466 |
| 11 |
| ascertain how much measurement |
| error is attributable to testing |
00 | 55.500 |
| 15 |
| there might be five or 10 units |
| or parts tested per operator, |
00 | 10.766 |
| 19 |
| different measuring tools is |
| small enough that differences in |
00 | 26.033 |
| 23 |
| measurement to measurement, |
| repeatability variation, or |
00 | 39.900 |
| 27 |
| measurement systems analyses, as |
| well as a confidence interval on |
00 | 52.766 |
| 31 |
| interval estimates in the report |
| and obtain a valid 95% interval |
00 | 07.033 |
| 35 |
| calculate confidence intervals, |
| because we believed it would be |
00 | 23.400 |
| 39 |
| and the sum of the variance |
| components. Unfortunately, the |
00 | 38.266 |
| 43 |
| r&r study. So because variance |
| components explicitly violate |
00 | 57.300 |
| 47 |
| you were to use the one click |
| bootstrap on variance components |
00 | 10.566 |
| 51 |
| less. So when we were designing |
| fit mixed, and the REML |
00 | 27.933 |
| 55 |
| independent. So back to the |
| drawing board. So it turns out |
00 | 44.666 |
| 59 |
| in JMP. One approach is called |
| the parametric bootstrap that |
00 | 01.333 |
| 63 |
| comparison of the two kind of |
| families of bootstrap. So the |
00 | 18.333 |
| 67 |
| they're, they're not assuming |
| any underlying model. And it's |
00 | 37.200 |
| 71 |
| the rows in the data table are |
| independent from one another. |
00 | 52.766 |
| 75 |
| values, it has the advantage |
| that we don't have to make this |
00 | 09.866 |
| 79 |
| bootstrap simulation. The |
| downside to this is that you |
00 | 25.133 |
| 83 |
| do a quick introduction to what |
| the bootstrap...the parametric |
00 | 41.966 |
| 87 |
| to identify or wanted to |
| estimate the crossing time of a |
00 | 04.733 |
| 91 |
| 162.8. Now, we want to use a |
| parametric bootstrap to to go |
00 | 22.466 |
| 95 |
| has the ability to save the |
| simulation formula back to the |
00 | 35.933 |
| 99 |
| that uses the estimates in the |
| report as inputs into a random |
00 | 53.300 |
| 00.666 |
| 104 |
| And we take our estimates and |
| pull them out into a separate |
00 | 17.666 |
| 108 |
| And then what we have can be |
| seen as a random sample from the |
00 | 37.000 |
| 112 |
| formula column for the crossing |
| time. And that is automatically |
00 | 53.900 |
| 116 |
| those...on the crossing time, or |
| any quantity of interest. When |
00 | 15.366 |
| 120 |
| simulation, create a formula |
| column of whatever function of |
00 | 28.366 |
| 124 |
| derive quantity of interest and |
| obtain confidence intervals |
00 | 47.233 |
| 128 |
| the add in so that you're able |
| to do this quite easily for |
00 | 05.033 |
| 132 |
| 133 |
| we'll start by showing you how |
| to run the add in yourself once |
00 | 25.500 |
| 137 |
| first version was presented at |
| the JMP 2020 Discovery Summit |
00 | 42.566 |
| 141 |
| overview, but we'll show you the |
| references where you can dive in |
00 | 58.866 |
| 145 |
| perfectly fine as well. So I'm |
| going to go ahead and start with |
00 | 14.700 |
| 149 |
| makes use of the fit mixed |
| platform, right, created from |
00 | 31.333 |
| 153 |
| the add in will only work with |
| JMP Pro. So someone might, |
00 | 49.066 |
| 157 |
| want some measure like |
| reproducibility. So that would |
00 | 10.166 |
| 161 |
| as we said, to calculate the |
| estimate for these, there's no |
00 | 26.066 |
| 165 |
| columns here. The reality is |
| much, much, much more |
00 | 43.066 |
| 169 |
| of the estimate without |
| considering the worst case |
00 | 59.233 |
| 173 |
| production that the actual |
| variance is higher than they have |
00 | 19.733 |
| 177 |
| don't risk being out of spec in |
| production. So to run the add in |
00 | 35.700 |
| 181 |
| From here, I can select the |
| linear combination of confidence |
00 | 55.266 |
| 185 |
| simulations, you get a better |
| estimate of the confidence |
00 | 10.500 |
| 189 |
| 2500. I'm going to leave it as |
| 1000 here just for demonstration |
00 | 28.733 |
| 193 |
| operator or the batch variable, |
| and then press perform analysis. |
00 | 45.533 |
| 197 |
| purpose of this demonstration, I |
| think I will stop it early. |
00 | 07.733 |
| 201 |
| calculated confidence limits, the |
| bootstrap quantiles, which are |
00 | 28.933 |
| 205 |
| these two tabs. But if you'd |
| like to see how those compare, |
00 | 42.366 |
| 209 |
| so what does enough mean, enough |
| for your confidence limits to |
00 | 57.400 |
| 213 |
| stopped it before a thousand. So |
| that's how the add in works. And |
00 | 15.466 |
| 217 |
| distributed around the original |
| estimate, they are in fact |
00 | 37.366 |
| 221 |
| relaunch this analysis. So |
| you'll see that when the |
00 | 56.433 |
| 225 |
| European Discovery, required |
| bounded variance confidence |
00 | 16.766 |
| 229 |
| that, if that happens for some |
| of the bootstrap samples or for |
00 | 40.466 |
| 233 |
| early, again, I'll just let it |
| run a little bit. Yeah, so I, as |
00 | 00.966 |
| 237 |
| the samples are allowed, in some |
| cases, to be below zero. So in |
00 | 28.400 |
| 242 |
| simulation column here, this |
| column of simulated |
00 | 49.100 |
| 246 |
| see them both at the same time. |
| It's a bit... it's a bit tricky, |
00 | 16.300 |
| 252 |
| right components, it's a good |
| idea to run the add in directly |
00 | 31.766 |
| 256 |
| that column is then deleted. So |
| one thing to to mention, before |
00 | 50.500 |
| 260 |
| accounts for the skewness of the |
| bootstrap distributions, right, |
00 | 14.200 |
| 264 |
| that. And then the accelerated |
| takes that even further. So here |
00 | 27.200 |
| 268 |
| thing to mention is that the |
| alpha in this represents the |
00 | 43.700 |
| 272 |
| value for which it's been |
| calculated? And what can we do to |
00 | 03.233 |
| 276 |
| up to investigate the four |
| different kinds of the variance |
00 | 24.700 |
| 280 |
| method, the bias corrected |
| method and the BCa. We also |
00 | 43.000 |
| 284 |
| study. So for all 16 |
| combinations of these three |
00 | 01.566 |
| 288 |
| combinations of confidence |
| intervals, and kept track of how |
00 | 20.400 |
| 292 |
| 293 |
| coverage as we're varying these |
| three variables, and we see here |
00 | 45.300 |
| 297 |
| 298 |
| techniques. And the second best |
| is the bias corrected and |
00 | 09.966 |
| 302 |
| the best one. Now, if you turn |
| no bounds on, which means that |
00 | 28.433 |
| 306 |
| variance components with a |
| pretty close to 95% coverage. |
00 | 48.200 |
| 310 |
| intervals are performing |
| similarly at about 93%. But |
00 | 02.200 |
| 07.800 |
| 315 |
| to what a master's thesis paper's |
| research would have, would |
00 | 27.966 |
| 319 |
| potentially more work to be |
| done. There's other interval |
00 | 42.566 |
| 323 |
| things like generalized |
| confidence intervals. General |
00 | 59.466 |
| 327 |
| intervals might also do the |
| trick for us as well. Hadley's |
00 | 19.966 |
| 331 |
| so that you can now do |
| parametric bootstrap simulations |
00 | 37.566 |
| 335 |
| 16. When you bring that up, you |
| can enter the linear combination |
00 | 51.766 |
| 339 |
